How the heck is one supposed to get the PS pump tight?
Old Aug 19, 2002 | 05:41 PM
Xenodrgn's Avatar
I've had this problem since I got the car... the PS pump never seems to be tight enough... well yesterday I took my AC belt off (it doesn't work, less mass for the engine to spin) and the PS belt had to come off...
I figured no problem I'd be able to get it tight enough...
Well now at accelerating RPMs and turning the belt is slipping and I'm loosing some of my power assist...
How the **** can I get that belt tighter... I used a lever to pry it tight... but now it's worse... I don't get it...
Help...
Old Aug 19, 2002 | 06:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You just gotta use a lever; not too much help out there... kinda sucks.. I wind up retightening my belt two or three times in a row because it doesn't seem tight enough. What sucks is, there's nothing really sturdy to pry against... especially the power steering pump, we can't pry against the plastic reservoir or we might crack it!
Old Aug 19, 2002 | 08:50 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I poked a hole in a tank once. using a crowbar to try and tighten the belt.
took alot of blue rtv and a big *** bolt.
Old Aug 19, 2002 | 09:35 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Did you try a new belt? Tight is right. Too tight is broken.
Old Aug 19, 2002 | 11:33 PM
Xenodrgn's Avatar
It's not too tight, believe me...
I'm jealous of how tight redZ28chik can get her belts... here I am limping along...
It has nothing to do with it being a new or old belt at all (belt is a year old)... there is still plenty of room to have it adjusted right...
i'll see if I can't enlist my fathers help tomorrow and give it another try...
Old Aug 20, 2002 | 08:25 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Make sure the nut on the back of the pump is there.. my 85 was missing it and I couln't get the belt to stay tight
Old Aug 20, 2002 | 01:16 PM
Xenodrgn's Avatar
Yes, that nut was missing on mine as well, however I discovered that and put one on about 9 months ago...
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
xxx3man`
Sep 23, 2015 10:37 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
novaderrik
Aug 10, 2015 12:44 PM
