starting problems
Old Sep 8, 2002 | 05:53 PM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
starting problems
first of all my car needs fixed.
my egr valve is broken and i have removed it from the exhaust manifold until i can fix. it sounds like **** too
plus i need a new water pump it leeks coolant
some times i start my car to move it and it wants to stall and if i put it in gear it wants to stall but if i rev it up or let it sit and warm up it want stall. it has done this ever since my egr valve broke. would the egr valve or the water pump have anything to do with this. or is ti some thing else i have to fix?
Old Sep 8, 2002 | 08:14 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
EGR probably has a big role in the stalling problem. Replace it and you will probably have normal idle back.
Water pump. I replaced mine before I sold the car, the only thing I noticed when I replaced it was cooler running temperature all the time. Not difference in the way it ran at idle.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
