Ok I need to know which plug to do I pull to set the timing. The gray one with the white wires is the tach right?? So I need to pull the one thats black with wires that are brown with a black strip right???
Quote:
Yes, it's near the passenger strut tower. Engine speed will change and SES light will come on. Originally posted by Ryan_Alswede
After you re-connect it, the engine will stay in base timing until you cycle the key OFF once.
Thanks i check, i think it's right on anyway but just want to check.
