when i stop, I get a big jerk from rear end
Old Oct 5, 2002 | 02:45 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
when i slow down my bird and stop, I feel a lurch, think it comes from the rear , like when shifting in drive, only much harder.
any suggestions, whats the cause?
thanks in adv.
Horst
Old Oct 5, 2002 | 08:05 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I am not a expert, but check your u-joints, all the bushings in the arms, and the torqe arm mount up buy the tranny. Thats my .02 cents.
Plus I'll move ya to the top of the list.
Old Oct 10, 2002 | 08:10 AM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I am no expert either but could it be a bad transmission mount?
Old Oct 11, 2002 | 02:50 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
Thanks so far Dale and Josh, I'll check this.
Horst
Old Oct 11, 2002 | 12:37 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
How far from a stop is it doing this? Does the engine rev at all? Maybe it's a really hard/early downshift to 1st?
Old Oct 11, 2002 | 01:06 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
It happens very short before the car stops moving.
You got an idea nixon?
Horst
Old Oct 11, 2002 | 03:56 PM
Nixon1's Avatar
Not particularly..just kicking some ideas around hoping someone will stumble over here and read all this and have a right idea.. So like RIGHT before the car stops right? I assume your car is an automatic...the car downshifts into 1st like immediately before you stop, otherwise it remains in 2nd, because 1st is geared so low that if it shifts into it at anything other than very very close to a stop, the engine will rev up pretty good. I've heard there's something internally in the transmission, like a...cushion that wears with time and can cause harder, rougher downshifts and stuff, but this was from a friend of mine that isn't the most knowledgeable...but I know little about transmissions so I can't know for sure if any of that part is true or not. Anything else strange with your car's operations, in concern with the transmission/rear end/torque converter, we should know about?
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
