2.8 V6 PS Pump Removal?!?!?
Old Oct 9, 2002 | 07:04 PM
89RSOwner's Avatar
Cant get the damn thing off, when all the bolts are removed from the "shield" it still stays rock solid. I see the pump is attached to it with three bolts and the bracket behind it is attached to the block with one. Shouldnt it come off if all the shield bolts are off in front? 2 bolts it is, (that I can tell).
-89RSOwner
Old Oct 9, 2002 | 09:29 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
There are 2 nuts on the back of the pump holding it to the bracket. Either 13 or 15mm.
Old Oct 10, 2002 | 01:05 AM
89RSOwner's Avatar
So just take those two bolts off and remove the pump?
Old Oct 10, 2002 | 01:14 AM
Engine: LH0 3.1L
Yeah, there should be:
-1 small bolt into the water pump
-2 or 3 long bolts into the brackets
-2 nuts behind the pump
That's it.
Are you removing the pump completely?? If you're pulling the water pump, just push the PS pump aside. Don't let it hang though.
Old Oct 10, 2002 | 01:16 AM
89RSOwner's Avatar
Nope just replacing the PS pump. It's seizing alot and was the cause of my /loose/broken alt. pulley. So it needs to be removed and replaced, ASAP.
Thanks Cali.,
89
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KED85
Jul 1, 2022 11:59 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
rjcme
Sep 5, 2015 01:23 PM
