how do you take off/put on ignition rotor???
Old Oct 9, 2002 | 09:08 PM
squirrelybird's Avatar
i went to change my cap and rotor.....my crappy haynes manual says "the rotor is held on by two screws" hmmm maybe on a v8??? on mine (3.1), there are no screws...none on the replacement either. well, i couldnt figure out how to get the damn thing off....figured its better to ask than to force it and end up stranded.
Old Oct 9, 2002 | 09:18 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
No screws. You're right, that's only on the V8's.
You just have to pull it off. It can be a huge pain sometimes. If worse comes to worst, I'll put some channel locks on it and just twist it off.
Once you get it off, spray a little bit of WD-40 on the shaft and then try to clean up the surface with some fine sandpaper. If you do put some WD-40 on it, just spray a little on the end of the shaft and dry it off before you put it back together.
Old Oct 10, 2002 | 09:01 AM
damn really? i pulled a little, but that bay wasnt budging, and i didnt have any gloves on at the time (i cherish my hands). So i assume the new one just pushes on then???
Old Oct 10, 2002 | 10:00 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Yep, mine was rusted on like a M/F when I bought the car, spent about an how hammering a screw driver on it to "chisle" it off in the guys yard I bought it from. I told myself I would drive it home w/o brakes and high gear.
I DID!!!!!!!!!!!!!!
I also took a finger nail file, and some wd40 and lubed that baby up once I got it off.
Old Oct 10, 2002 | 04:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I had that problem a few times... careful when pulling, you could scrape the back of your hand against the cowl if the rotor suddenly comes free. (ouch!) You could also try prying up on the rotor with a big screwdriver, using the back of the plenum as a pivot point.
Old Oct 12, 2002 | 01:53 PM
for anyone else who might wanna know....i did it while the engine was hot and it pulled right off quickly and easily.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
