Question
Old Oct 24, 2002 | 01:24 AM
jesse23's Avatar
Question
MY friend said in camaro's if you remove the AC u gain HP? And it also takes off like 75-8-lbs. Is this true. I can see the weight loss, but how a HP gain? he said the belts and stuff
Old Oct 24, 2002 | 08:16 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Well you really don't gain horsepower.
What happens when you remove the AC is lessen the weight (you knew that) and get more horsepower to the wheels due to less friction and "parasitic loss" that the AC compressor took away from the motor.
Old Oct 24, 2002 | 09:22 AM
jesse23's Avatar
how much gains we looken at?
Old Oct 24, 2002 | 09:26 AM
MDv6man's Avatar
Car: 1983, 1986
Hard to say w/out a dyno... my guess would be no more than 10 max.
Old Oct 24, 2002 | 10:03 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
75-78pds? that's stretching it. a lot. the compressor off my 77 T/A weighed maybe 30-35lbs. but to get the full effect, remove every part of the A/C. Ask TomP, he has like 50 billion pages on this.
Old Oct 24, 2002 | 02:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah the compressor isn't that heavy... 30-35 pounds is probably about right. The condensor in front of the radiator (cause when you look at the car from under the front, you're not seeing the radiator, you see the condensor!) is only a couple pounds, as is the silver accumulator can & the evaporator (connected to the accumulator, inside the heater/evaporator box on the firewall). Removing it does give some more room to work on the motor, though.
I removed mine for two reasons, 1, I never used it, I prefer to drive around in summer with the windows down & the radio up. And 2, when I totalled the car, the evaporator got mashed (heater/evap box shattered, too). I could bend the condensor back, bent all the hard lines back, but that evaporator was like a solid chunk of steel. So no big upset for me when I just dumped the whole system onto the grass.
Only times I wish I still had it back is when I'm dressed up for something, wearing a shirt & tie & suit in 90 degree weather... my anti-perspirant never holds up!
Old Oct 24, 2002 | 03:03 PM
MDv6man's Avatar
Car: 1983, 1986
That's what they make it for
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
