Some Injector Help
Old Oct 25, 2002 | 11:45 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Some Injector Help
I am bored at work, came across this, since their is always a big deal about what size injectors need to be ran, come with, bla bla bla.
basically take.........
(estimated power X .50) / (amount of injectors X .80)
so, using the 3.4l figures (my engine swap )
(160 X .50) / (6 X .80) = 16.66 lbs
http://www.jimsperformance.com/tech.html
Hope this helps!!!
Old Oct 25, 2002 | 12:57 PM
Dale's Avatar
Engine: 350 S-TPI
BTW, what is the stock power rateing for the 3.1l??
Old Oct 25, 2002 | 01:00 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
140hp@4400rpms
180ft/lbs torque @3600rpm
Old Oct 25, 2002 | 03:05 PM
Dale's Avatar
Engine: 350 S-TPI
TY, so basically the 3.1l needs 15lb injectors. Hum, maybe my 19lb's would be a bit much??
Old Oct 25, 2002 | 03:34 PM
MDv6man's Avatar
Car: 1983, 1986
I think you could get away with it. Consider this -- I believe the 2.8's injectors are rated at 16 lbs/hr. Even if everything was the same as a 3.1, our injectors would be too big.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
