NOS kit part #?
Old Nov 17, 2002 | 12:48 AM
Berlinetta's Avatar
NOS kit part #?
where can i get the NOS kit for my 85 2.8L car? I cant find it on the Jegs or Summit website.
Old Nov 17, 2002 | 12:15 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
I remember some guy on this board(i 4get his name) installed a mustang setup into his car... In the top right hit search and make sure u select the v6 forum, Search for mustang nos or something.
Old Nov 17, 2002 | 12:17 PM
Pontiacguy1 Says:
When I installed my Nitrous kit back in 1996, NOS recommended the 5.0 Mustang nitrous kit for use with MPFI 60* V-6 cars. At least that is what the tech guy I talked to said. The kit was WAAAAAY cheaper than $670 too. There is a non-adjustable kit for 86-93 5.0 Mustangs that is pre-set for 75 HP gain. It is the 05115 kit, and it is listed in the Summit Catalog for $469.95. I didn't get any specifics about the system, but make sure it has a throttle body switch so that the system only activates at WOT. If not, you could damage something.
My kit is adjustable from 50 to 150 HP, but since I set it up for a 75 HP shot, I don't see that there would be any difference in the performance between the two kits. I don't think it would be hard to install, and would cost a lot less money. I have mentioned this several times in other threads, but it keeps coming up, so I keep letting people know what worked good for me. BTW, my car is a 1992 Firebird 3.1 liter Automatic, in case anyone was curious. The kit has been on since spring 1996, and I haven't had any problems with either the engine or the kit.
Old Nov 17, 2002 | 02:18 PM
Berlinetta's Avatar
I know that when you inject nitrous into a motor you have to inject a corresponding amount of fuel, otherwise you will run lean and fry a piston. How does this kit you mention add extra fuel? Does it use the fuel injectors?
Old Nov 17, 2002 | 02:32 PM
I have no idea what it does i just searched on the oards and found that.
LT1Formula
20
Nov 14, 2015 12:02 AM
fasteddi
Sep 2, 2015 10:29 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
