HELP! What is the size of the Distributer hold down bolt?
Old Nov 19, 2002 | 07:07 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
We have a distributer wrench to losen the distrubuter one end is 9/16 and the other is half inch.. neither well fit on, how the hell am i gonna do this?
POs i need to adjust the timing its 6 deg its gotta be 10 deg.
thanks
Old Nov 19, 2002 | 08:20 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Probably a 15mm. If not, try a 13mm.
Old Nov 19, 2002 | 11:08 PM
KED85's Avatar
15mm or 17mm
How to do this.
Easy.
Sears
Craftsman Swivel end socket on ends of several long extensions
It can only be easily done this way.
Old Nov 20, 2002 | 07:15 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
15mm
Old Nov 20, 2002 | 08:54 AM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
Transmission: TH-700R4
ked...dale...and cali are right...i'll just chime in to say 15mm myself...i did it with a swivel head ratchet...1 6 inch extension and that 15 mm swivel head socket...put the extension + socket on bolt first...clip in ratchet and turn a couple times just until you feel a slight drag on distributor...but can move it...then time away...also don't forget to disconnect the EST...
Old Nov 20, 2002 | 09:16 AM
AFreaknGoodTme's Avatar
buy a 15mm box wrench and cut it in half (cut of the open end wrench side) and keep it in your tool box just for this purpose
O------C O---/---C = O--- Makes life easy.
Old Nov 20, 2002 | 09:25 AM
Dale's Avatar
Engine: 350 S-TPI
W-m sells the "shortie" wrench set for 15-17 bux, thats what I do mine with. Works great, and you get from 10 to 17 I belive
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
pimprs
Aug 24, 2015 11:20 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
