2.8 fuel pressure
2.8 fuel pressure
hey guys, i was wondering if there was any way to increase the fuel pressure in my 1987 camaro 2.8L v6 because i swapped a 3.4L into it and figured the extra fuel pressure would help feed the extra ci.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
You need bigger injectors, not fuel pressure. Put the injectors from the 3.4l in their.
Both the 3.4l and the 2.8l use same fuel PRESSURE, just diff lb injectors.
Engine: 350 S-TPI
Yes, thats what everyone does with the multiport 2.8-3.4 swap. The 2.8 comes with 15lb, the 3.4 comes with 17lb. Swaping injectors is what you need to do.
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
