Cat Conveter replacement
Old Dec 1, 2002 | 07:57 AM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
OK...its that time to replace the cat.I noticed it had a dent on the belly side of it and some stuff probably got to the muffler as well.I am going to put a direct fit OEM type cat back on it.It seems to be bolted on rather than welded.2 questions:
1)Is there any thing special i need to do as i am taking the old one off and installing the new one.I'll cut off the old brackets.And...
2)Will i be able to do the job if i ran the car up on car ramps?Will this give me enough roo to do the job?THANKS GUYS
3.1 V6
Chrome IROC-Z rims
Poliished plenum
Flowmaster muffler
cold air intake(pics coming SOON!)
Old Dec 1, 2002 | 02:56 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
You sure it's bolted on both ends?? Mine was bolted on 1 end and welded on the other.
You should be able to get an exhaust shop to do it for ~$30.....better than trying to weld on your back.
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Out-Cast
Aug 22, 2015 07:49 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
