Putting Tranny on engine.
Old Dec 3, 2002 | 09:58 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
When I go to install my tranny on this new engine. My pops is worried that their is a "piolit bushing" in the back of the engine somewhere that needs to be changed like back in the old days.
Rem, this is a manual tranny, and I will be installing on the 93-95 3.4l engine.
direct bolt?? no need to change any bushings n crap?
Old Dec 3, 2002 | 10:50 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
just inspect it to make sure it's not out-of-round. If so , replace it. Actually, go ahead & replace it. When I did my engine swap in the T/A, I replaced the solid bushing w/a roller one. got it @ Nappy. might be the only place besides dealer to get one.
Old Dec 3, 2002 | 11:52 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Re: Putting Tranny on engine.
Yeah, the pilot bushing is used to support the front of the input shaft on manual trannies. Replace it....it's only about $10 unless you get a roller.
Old Dec 4, 2002 | 07:00 AM
Dale's Avatar
Engine: 350 S-TPI
Great, thanks for the info.
project, any Idea what the part # is for that roller one??? I'm going to roller timing chain, and eventually go to roller rockers, why not a roller piolit shaft bushing.
How do I go about getting them in and out?
Also, the engine came from automatic, and I'm putting manual on it. I know I have to change flywheel, will this make difference on the bushing??
Much thanks all :hail: :hail: :hail:
Old Dec 5, 2002 | 12:05 AM
Engine: LH0 3.1L
A tranny guy once told me that a solid pilot bushing will last longer than a roller......but that guy was a grade A moron so I can't trust what he says.
Getting them out is the hard part but you don't have to worry about that because your new engine doesn't have one. You can just tap the new one in. Don't forget to lube it.
The flywheel does not change anything regarding the pilot.
Old Dec 5, 2002 | 06:56 AM
Dale's Avatar
Engine: 350 S-TPI
Um, I would have to think (oo, their I go using that word again ) that the rollor would last longer provided it gets oiled properly.
thanks for the info
gta90
Sep 15, 2015 04:00 PM
Thornburg
Aug 25, 2015 01:46 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
