Balancing
Old Dec 20, 2002 | 08:54 PM
89 TA's Avatar
Car: Trans Am/Kenworth
Engine: 383/435 Cat
Transmission: T5/10 speed
Balancing
When rebuilding a 2.8 V6 do you have to balance the rotating assembly?
Old Dec 20, 2002 | 09:10 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Do you mean balancing the crankshaft? I believe our crankshafts are internally balanced, so as far as a harmonic balancer, we just need a neutrally balanced one. But don't quote me on that..I'm no engine tech.
Old Dec 21, 2002 | 03:27 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
is it just a re-ring? or are you installing new hard parts?
just a re-ring, you should be ok
new hard parts, balancing is advised
Old Dec 22, 2002 | 05:12 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, harmonic balancers were all neutral balanced from 82-92 (and probably 93-up, as well). But 82-86 2.8's are externally balanced, on the flywheel. Makes things kind of a bitch, especially if you're trying to change an 82-86 flywheel. But 87 started the year for the DIS-equipped Gen II motors, so a center counterweight was added (with notches for DIS), which allowed the 2.8's to be internally balanced. The Gen I motors, starting in '87, used the same crank as the Gen II's, even though the notches on the counterweighta ren't used for DIS.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
