shakey volt meter!!!!HELP PLEASE
Old Dec 23, 2002 | 10:13 AM
aaronkark's Avatar
Does anyone have any idea what could cause a volt meter at the dash to shake all over the place. My lights will flicker a little at night. I replaced the alternator...NO LUCK!! Any other ideas? I would really like to avoid having to take it in to a mechanic. By the way no codes are coming up. Thanks, Aaron
Old Dec 23, 2002 | 01:07 PM
Camar_Hunter_c's Avatar
alternator or battery, maybe a bad wire.
Old Dec 23, 2002 | 03:02 PM
mvftw's Avatar
Must have a Good Ground!
Old Dec 26, 2002 | 04:04 PM
if no good ground, car no run.
Old Dec 26, 2002 | 04:20 PM
grimesjm1's Avatar
poss. could be voltage regulator
Old Dec 26, 2002 | 11:55 PM
AFreaknGoodTme's Avatar
Hows your idle, is it jumping around as well or is it stable?
Old Dec 27, 2002 | 06:46 AM
KED85's Avatar
EVEN IF
you already replaced alternator, do it again, especialy if it has a warranty.
WHY?
You'll probably solve the problem that way, best.
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
