Testing Injectors
Old Dec 23, 2002 | 08:52 PM
Twix's Avatar
Testing Injectors
Okay guys, this may have a very simple answer, but I'm not 100% how to go about doing this. Could someone tell me the full/entire process to test my fuel injectors?? Much Thanks In Advance!!!!!!
~~**Twix**~~
Old Dec 23, 2002 | 11:47 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I am not 100% sure how to do this. So I am going to send this back to the Top for the more expierence to answer.
Old Dec 24, 2002 | 12:05 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
For one, you have to remove the upper plenum to get to the injectors. This makes testing them a pain and most people won't test them because of this. Plus you need TB and plenum gaskets.
Second, you need a fuel pressure gauge and a tool like the one shown here: http://www.actron.com/cgi-bin/web_st...9.htm&cart_id= With this tool you can do injector balance tests. Basically you can manually pulse any injector and record the pressure drop. All injectors should be within 5 Kpa of each other.
Also, injectors can show OK on the balance test but could still be shorted internally. For this you'd need a injector coil tester/voltage drop tester like the one shown here (pricey) :
http://www.handsontools.com/store/sh...roduct_id=1912
Oh yeah, this isn't the greatest test but......you can use a regular Ohmmeter and check the resistance of each injector. A bad one might not show up on this test, but say you test them and 5 injectors have 7 ohms resistance and 1 has 1 ohm.....then you know that one injector is bad.
92projectcamaro
Jan 18, 2016 08:00 AM
BAMiller
Sep 14, 2015 06:38 PM
greenyone
Sep 2, 2015 03:39 PM
Jae992
Aug 27, 2015 09:07 AM
