Dynomax exhaust going on...
Old Jan 10, 2003 | 11:21 AM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
Transmission: TH-700R4
well...sitting in my garage is a brand new dynomax super turbo cat back exhaust system...i got a question about something...well...i need a cat...and i could only buy the exhaust system for now because mine has rotted out and is falling off...and just to have a new center pipe put on and 2 tail pipes onto my existing flowmaster was gonna be 271.20...no way would i pay that when i could buy the new system for 155...anywayz...should i hollow out my cat for now because it is clogged up and when i gather some more cash just put a new one...also...will this system for my 2.8 fit my 3.4 when i put it in...i wouldn't see why not...well..thanx guyz...
Old Jan 10, 2003 | 11:25 AM
86camarodriver's Avatar
Yes it will fit if you use the 2.8 intake on the 3.4 it will look exactly like the 2.8, this is how the California boys pass the visual inspections LOL.
I would replace the Cat withe a cut-out, it will save you some money and you will get some more power.
Let me know how it turns out I want to get the dynomax with the 3.4 here sone.
David
Old Jan 10, 2003 | 12:15 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have a 3.1 with dyno max, and gutted cat. But I also have a exhaust leak between the both.
Before you take one part of your car, make sure that "clamp" that bolts up to the cat is on right. Mine was put on backwards buy dynomax and I didn't notice it tell it was in car, and that was the last thing I was bolting up. No way I was gonna take it down just for that. So I rigged some stuff up for now.
Gong to a 3.4 will be no problem with that catback
Old Jan 10, 2003 | 01:24 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Avoid gutting or hollowing your cat as well... It creates an open chamber where exhaust gases will expand and ruins the airflow... Instead, gut it and run a pipe through it...makes better power that way.
Old Jan 10, 2003 | 10:00 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
will our car pass inspecitons without the cat?
Old Jan 10, 2003 | 10:03 PM
Nixon1's Avatar
Highly doubtful.
Old Jan 11, 2003 | 12:37 AM
Dale's Avatar
Engine: 350 S-TPI
very very doubtful. Sound is obvious, and more fuel smell is obvious. Let alone is not their to do its job.
zapr
Jul 27, 2018 06:03 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
Tarizza
Sep 24, 2015 12:57 PM
david068513
Sep 18, 2015 10:36 AM
