Rear end questions
Old Jan 13, 2003 | 03:16 PM
PeNZ's Avatar
Rear end questions
Ok I might be getting a rear end/panhard bar out of a 90 iroc, it has 3.73 gears vs. my 3.23 how will this effect my speedo and my speed that my car gives, and will the panhard bar bolt up to my car?
Old Jan 13, 2003 | 05:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If the panhard rod is stock, then it's the same one you have on your car, don't even bother swapping them.
Did the guy put 3.73's in or did he claim they came from the factory? '85 was the last year for a factory 3.73 ...
Old Jan 13, 2003 | 08:55 PM
AFreaknGoodTme's Avatar
I atcually went from 3.42's down to 3.23's and found that the car pulls much better in the powerband. 1st gear is so high in the 700r4 that the lower rearend made it more useable . It doesn't tack out as fast and over rev. 3rd gear is more useable on the freeway were before it would modulate between 3rd and fouth on a steep grade.
Old Jan 13, 2003 | 10:59 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
you know if I could do it cheap enough and in a few hrs I would love to just throw in a set of 4:10's
1 wheel peel would be fine with me.
all I got now.
wonder what cars or trucks came with 4:10 / 11s that would fit into out rear end. you know something that would cost about 100 bucks or less used.
Old Jan 13, 2003 | 11:52 PM
85_sc's Avatar
My 85 s-10 came with 4:11's from the factory and it had a dealer installed 350 but i don't know how many s-10's came with 4:11's i know alot had 3:42's and 3:73's.
Old Jan 14, 2003 | 12:19 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I actually found out the same when I went from 3.42's to 3.73's... not only did I get off the line quicker (due to the 700r4's 3.06 'granny-low' 1st gear) but <b>4th</b> gear became more useable on the highway. I could actually use 4th to accelerate, and even pass people much easier! (I also installed the B&M 4-3 kickdown kit way before I went to the 3.73's, so I was able to use 4th to accelerate before, but the 3.73's really woke the car up!) I cant wait to fix that blown posi and get that 3.73/posi/disc axle back under my car!
Old Jan 14, 2003 | 08:50 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Without some documentation, I'm callin'
Old Jan 14, 2003 | 09:18 AM
Trent257's Avatar
im selling him the rear, i want to go from mine which has 3.73 not stock to a 4th gen disc setup with 3.73's. how hard is it to swa gears? i was just gonna buy a 4th gen with 3.23's or something and swap them. his car does not come with a panhard bar.
Old Jan 14, 2003 | 09:46 AM
Just to let you know, 4th gen rearends are wider than 3rd gens.
If that is Penz Firebird in his signiture above--then I don't know what you guys are talking about him not having a panhard rod? You do know those car came stock with one? and that if he didn't have one in there the car would not be drivable-- it would not even sit properly just parked- He has to have one-look again.
Old Jan 14, 2003 | 11:03 AM
MDv6man's Avatar
Car: 1983, 1986
Ditto that... Last january the panhard rod broke on my 85. Let's just say that I have new respect for the term "body roll"
Old Jan 14, 2003 | 12:14 PM
Trent257's Avatar
thats just what he told me, yea i know 4th gens are wider, but it works on because im getting wheels that would need spacers neway
Old Jan 14, 2003 | 12:32 PM
PeNZ's Avatar
I just looked and yea I do have a panhard bar
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
