What is the stock idle RPM?
Old Jan 14, 2003 | 02:25 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Hello all, I have a 1989 Pontiac Firebird Coupe with a 2.8L... I want to know what is the factory idles RPM? When the engine is warm? 'Cause mine seems so low, moves from 500 to 600RPM when hot... And what could make the engine speed vary continuously like this when it's idle? Thanks!
Old Jan 14, 2003 | 03:17 PM
86camarodriver's Avatar
Mine likes to stay right at 1k but I am still working on droping it down some.
As long as you are under 1k you are fine, I replaced my plugs and that smoothed it out some. Unless it is doing a jump and back from like 300 to 1k I would not worry about it.
Old Jan 14, 2003 | 03:49 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Okay but I would like to adjust it at the right RPM like it was when it went out of the factory... And my car seem slower now that it idles at only 500-600RPM. Especially on the start. If someone have the xact number, please help me
Old Jan 14, 2003 | 05:41 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Let me try to clear up what I've said... Let's say that I'm at a red light, in D position... I wan't to know the exact RPM I'm supposed to have. Sorry for my bad english again...
Old Jan 14, 2003 | 05:58 PM
AFreaknGoodTme's Avatar
Mine stays between 700-750 in drive and 800-850 in park. The fluctuation in idle rpms could be bad vacuum lines, I'd suggest starting with that, then IAC, or EGR could be going south.
Old Jan 14, 2003 | 06:05 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Okay, thanks for the answer. Are the other people of this board have the same as him?
Old Jan 14, 2003 | 06:51 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
yea, i had a vacuum line break (right on the backside of the upper portion of the intake manifold) a little while back and the idle RPMs dropped to about 500 where they are normally about 750 with shifter in D (or OD).
Old Jan 14, 2003 | 06:55 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
I have a 1987 Camaro Sport Coupe and a 1989 Camaro RS, both with the 2.8L V6 and both have the 5-speed manual T5 transmission. Both idle at 750RPM - rock solid (when warm or started on warm day). 1500RPM when just started on a COLD morning, drops to 1000RPM after a few minutes, then settles to 750RPM after a few more minutes.
Old Jan 15, 2003 | 05:45 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
i think i'm about 550-650 in park and 4-500 in drive.
goes almost to 300 for a second right when i hit the brakes and stop, then goes up a little.
Old Jan 15, 2003 | 07:04 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Thanks for the infos So the to be right I have to try to get 750RPM when I'm in drive... Thanks!
Old Jan 15, 2003 | 07:23 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Hum, deff shows somthings wrong with mine ideling at 1200 rpms.
Old Jul 2, 2012 | 05:32 PM
Ant Gratz's Avatar
Re: What is the stock idle RPM?
well we just did a tune up and its idlen from 2000-4500rpms sooooooo yeh help? please!!!
Old Jul 3, 2012 | 09:13 PM
Car: 91 Camaro
Hi, welcome to the boards. Feel free to start a new thread as this one was last replied to in 2003. Anyway, are you sure its idling that high or is it just the tach showing that? Its not uncommon for the tach to be way off.
Old Jul 11, 2012 | 09:10 AM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Still sounds vacuum related to me.
My fuel injected 92 v6 idles @ 1100-1200 cold, 1000 in park or neutral when warm and 750-800 in drive or reverse. If you reset idle, timing … always reset the computer, so the computer can relearn the settings. Every once in awhile right after resetting, from a stoplight, floor it. That way the computer can learn the extreme fuel curve.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
jbd1969
Aug 17, 2015 07:06 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
