Sparks
Old Jan 22, 2003 | 07:30 AM
NickHell's Avatar
Sparks
I went to change the spark plugs on my V6 91'. I'm confused though because there are only four spark plugs. What's the problem here?
Old Jan 22, 2003 | 07:52 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
What do you mean only 4 plugs??
I know two of them are pita to get to on the passenger side, but they are their.
If you truely do only have 4 plugs in it, thats got to be running like major A$$
Old Jan 22, 2003 | 09:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Sparks
You have to stop picking on those ricers. One of them got mad at you and took two of your plugs so your car would be as slow as theirs.
RBob.
Old Jan 22, 2003 | 01:00 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Your missing two plugs are probably below the EGR setup. Its a mess under there.
To find all your plugs, simply take each wire on the distributor and trace it back to each plug. Start with 6 plugs, trace each wire back one at a time. When your done all should be changed.
Old Jan 23, 2003 | 12:55 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Ha ha..imagine that.... I've run on only 4 cylinders before. Wasn't a fun time. Car felt fine though! Just backfired like crazy.
Old Jan 23, 2003 | 03:11 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I've accidentaly left 3 of my wires off before. My g/f called me during my plug swap and I didnt finish putting my wires back on, LOL. The motor ran real rough but sounded soo bad azz. It's a lovely roaring sound to hear. But it scared the pants off me until I figured out what was wrong.
Old Jan 23, 2003 | 06:23 PM
Nixon1's Avatar
Ha ha... Yeah, it started fine, all I heard from the engine was a tick tick tick..like a tapping noise...was coming from the valve cover region...I freaked after hearing that, thinking busted rocker arm or something... Then I listened to the exhaust, and it sounded like it had a cam in it. Revved it up a tad and it backfired and missed all over the place and I found out what it was then.....
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
