injectors
Old Jan 26, 2003 | 08:15 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
injectors
i found a set of 19# injectors from a 92 Z-28. will they drop straight into my 91 3.1 (minus 2 obviously)? will any gm injectors work?what will fit the stock fuel rail and wiring harness? Thanks for all info.
Old Jan 26, 2003 | 08:45 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Will "stick in" fit, but I hope you have some serious mods done to engine to need 19lb. I installed 17lb in mine and was more then it needed.
Old Jan 26, 2003 | 09:27 PM
WaynesRS's Avatar
I agree Dale . You will be running richer than Bill Gates if you dont have some serious mods .
Old Jan 26, 2003 | 09:33 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
agreed to justify 19 lb injectors on such a small engine you better have some serious mods to get the required air in
i.e. ported heads, ported intake, pretty good camshaft
think about this: a 2.8 is less than half the size of the 305 those injectors came off of............
food for thought
Old Jan 26, 2003 | 10:01 PM
Camar_Hunter_c's Avatar
Uhhh. I dop not have "serious" mods. just a few and I am running 19lb'ers with no trouble at all. I also reset the computer before starting up so it could recalibrate for the larger injectors, but the bothersome "lean" spots disapeared.
Old Jan 26, 2003 | 10:09 PM
thats very strange since your drastically changing your injectors' duty cycle............
Old Jan 26, 2003 | 10:12 PM
Car: 91 Camaro
oh yea, definately got serious mods. motor's not in car yet but almost ready to go in.
ported/polished heads: check
ported intake: gonna be (once i pull it off of old motor)
pretty good cam: BIG check
list goes on...
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
