who has a Z28/IROC grill insert?
Old Jan 28, 2003 | 04:39 PM
Erin91RS's Avatar
Car: 91 RS
Transmission: 700-R4
I have a 91 RS with the blah looking grill. I was looking on eBay and I see that I can replace my grill with a Z28 bowtie or Iroc "camaro" grill insert. I would like to get the one that says camaro. I was wondering if anyone has swapped out the the blah grill cover for a z28 or IROC cover and did you wire up the foglights or leave the space empty. Did the grill fit properly? Thanks.
Old Jan 28, 2003 | 10:08 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
You should just ask this on appearence and detailing, or the body board. I am sure it swaps right in. As for the fog lamps, I am sure this is no big deal when you hook them in. But try posting there, you will get tons of response.
Old Jan 29, 2003 | 02:13 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
I did exactly that with my car. Here's the picture of it showing the updated front. I also installed the stock fog lights and stock interior switch to the fog lights, and now it looks like the car came with them! Check out my webpage for more pics.
P.S. I have a spare Z28 grill here, if you can't find one, I could take pics and you could make an offer if you don't have luck finding one.
Old Jan 29, 2003 | 05:10 PM
Erin91RS's Avatar
Car: 91 RS
Hey that looks really good. Did it bolt right up? Did you add a seperate switch for the lights? My dad didn't want to splice the fog lights into the exsisting ones. He says we can possible run a wire from the lights, to a fuse, then to a interior switch. Does that make any sense? It sounds like a lot of work though. I think I'm gonna order the "camaro" grill through F-body motorsports if i can't get it cheap on eBay.
Old Jan 30, 2003 | 12:15 AM
Engine: 346ci LS1
Transmission: MN6
Thanks! Yes, it did bolt right up. I added the stock interior switch that goes right under where the headlight switch is. I also added a relay so that the fogs turn off when I have the high beams on, becuase that is a law.
Old Jan 30, 2003 | 10:27 PM
zer0321's Avatar
yep :-)
been there done that
looks way better than the RS grill:
Attached Thumbnails who has a Z28/IROC grill insert?-0009.jpg
Old Feb 9, 2003 | 12:10 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
I also, did this same thing except I have the bowite grill.
Old Feb 9, 2003 | 02:02 PM
Engine: 346ci LS1
Transmission: MN6
-Z28 grill w/ fog lamps w/ H3 HID Bulbs
Do you have those H3 bulbs in the stock fog lights? If so are they brighter?
Old Feb 9, 2003 | 08:15 PM
Quick6's Avatar
No and yes. I do not have the factory foglights. But, yes the new bulbs are brighter than the ones that were in them...
Old Feb 16, 2003 | 10:46 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
hmm i put fogs behind my BLAH grill as you call it and if you look at it my car already had the fog mount holes, saw this when i was swapping my front end from a wreck i was in (the car was in a wreck b4 cuz the nose said it was a 91 z28 LOL) but im looking on ebay to get the camaro grill as anybody else, cuz i have the IROC hood right now!
1990RSVERT
Exterior Parts Wanted
May 27, 2024 11:23 AM
Gunner242
Dec 25, 2015 04:49 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
