shaky ride
Old Jan 31, 2003 | 04:21 PM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
shaky ride
on top of my 3.1 having a loud hiss and the rough idle with jumping rpms, it is now very shaky literally
when i turn it on it has a rougher idle than before and it continues even while driving. it has even stall out a couple of times
as time goes on things keep getting worse and worse. it feels like my car is about to die!
since i know very little about engines or anything under the hood i am taking it to a garage tomorrow. what should i tell the mechanics to look for in particular? i wanna have them hook it up to a computer. if there is anything wrong which i know there is will it show up on the computer?
Old Jan 31, 2003 | 04:31 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
vaccum leaks
Old Jan 31, 2003 | 05:29 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
MD nailed it. Totally vacuum. Listen to the hiss..track the noise down by ear...look for disconnected hoses first...or hoses with big cracks in them. Check all the vacuum hoses..they're all flat black, usually made out of rubber I think. Replace the leaking hose. You'll know if it's the hose causing the roughness cause if it's cracked, wrap your hand over the cracked area...if it's disconnected, plug it back in where it should be or stick your finger at the end of it to seal it and your idle should jump right up. The best way I've found of tracing vacuum lines, most of them anyways, is to start at the back of the plenum. Examine all the hoses coming out of it, and the hoses connecting to those..trace them all down and that should be basically every vacuum line in the car...have fun!
69GTOby
Apr 18, 2016 02:34 PM
1992Z28!
Nov 19, 2015 07:33 AM
Linson
Sep 21, 2015 01:08 PM
amcnellis
Sep 16, 2015 04:16 PM
Ranbo108
Sep 9, 2015 12:20 PM
