Working on a '92 3.1... bad ecu?
Old Feb 7, 2003 | 10:53 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Code 33, 34, 42, and 43. Replaced the map with a known good one, no difference. If I crank the car, and shut it right back off, it sets code 33, 42 - if it runs for about 15 seconds or so (maybe 10) it sets 34 and 43. The knock sensor was disconnected, but I hooked it back up. Timing set to 10º BTDC.
I can get a ecm from the junkyard for $20, no return. How on earth can one test the ECU to see if it is bad?
Old Feb 7, 2003 | 12:14 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
not nessacerily
if you followed a diagnostic flow pattern (usually found in GM manuals) you will see that when a code sets, say a code for the MAP, its not nessacerilly the MAP that is bad..................could be bad wiring to the MAP, a clogged vacuum line, bad ecm, etc.
i suggest you follow a GM diagnostic flow chart for each of these codes
Old Feb 7, 2003 | 12:17 PM
funstick's Avatar
check the ignition module if the timing isnt working correctly its throw codes 33 and 34 due to an over or under rich condition. our getting EST errors 43 and 42 generally speaking that means the ignition module isnt working properly.
Old Feb 7, 2003 | 12:30 PM
Doward's Avatar
Ignition module was checked at Discount, all green lights. I popped the map vacuum line off, and it's got vacuum. How do you guys suggest I check the wiring for the map?
Old Feb 7, 2003 | 12:36 PM
Doward's Avatar
btw, I know a bad O2 is generally code 13, but would it affect any of these codes?
Old Feb 7, 2003 | 09:26 PM
Doward's Avatar
could the est module go bad?
I tried a new ecu, still the same codes... arg!
Old Feb 7, 2003 | 09:40 PM
funstick's Avatar
replace the ignition module. then take 2 aspirin and call me ithe morning.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
