knock sensor question
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
does anyone know exactly how the knock sensor works? does it use resistance between the plug and ground (block)? if it is just resistance, what is the resistance in the proper working condition? reason for asking is that i am planning to try to bypass it for my new engine. let me know if you got any info on this subject....thanks.
Car: check
Engine: check
Transmission: check
Re: knock sensor question
The ECM will think that the sensor is still there.
wire----/\/\/\/\------gnd
3.9k
RBob.
