3.4 wiring experts
Old Feb 19, 2003 | 02:58 PM
86camarodriver's Avatar
3.4 wiring experts
http://www.camarov6.com/cgi-bin/ulti...&f=13&t=000293
If I was to wire the 3.4 engine up for the 3.4 ECM (would love to keep the 2.8 stuff to keep is simple and make it a fast swap) I know it would be detailed but how much time are we talking? To do this you would have to use the 3.4 computer and intake also right? Or could I still use the 2.8 computer?
Since I am new to the electrical side when it comes to cars is the ECM under the dash or in the engine bay?
I guess I could wire in the ECM stuff but not connect anything and then when the swap comes just un plug the 2.8 ECM and plug in the 3.4 ECM.
Something tells me I am going to have to do a full wiring swap.
Does the benifets far out weight the cons on the 2.8 to 3.4 ECM?
Old Feb 19, 2003 | 03:04 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'm working on putting full 3.4l sfi-dis in my s10
Wiring is not simple of unplug and replug, TRUST ME
2 months to trace, jumper, lengthen, shorten the wiring.
Have to have ac lines MADE to fit.
You want easy swap, just do the popular block/head/crank/cam swap.
Benifits of 3.4l sfi-dis...
Few more mpg, no distributor.
Down side, if you want to pep it up, no oversized tb, have to buy 3 coils rather then 1, will need specail headers.
Old Feb 19, 2003 | 08:23 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
upside, there is a supercharger kit for the 3.4 being developed. uses the 3.4 serp belt setup.
Plan ahead for futer upgrades :rockon:
Old Feb 19, 2003 | 09:13 PM
Dale's Avatar
Engine: 350 S-TPI
O really?
I didn't know that one
Time to start saving the pennies again.
Old Feb 19, 2003 | 09:26 PM
Engine: 5.7 / 7.4
yup, turned out to be an unintentional benifit of my version of the swap.
and Dale, you're version 3.0 of the swap
Old Feb 20, 2003 | 06:54 AM
Dale's Avatar
Engine: 350 S-TPI
Ahh, version 3
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
92projectcamaro
Aug 6, 2015 01:20 PM
