3.4 heads?
Old Feb 26, 2003 | 08:08 PM
firechicken_-54's Avatar
Car: 85 firebird
Engine: 2.8 HIPO
3.4 heads?
will 3.4 heads fit on our 2.8 i know that the chamber is much bigger but i do belive they make headers for the 3.4
thanks peter
Old Feb 26, 2003 | 09:12 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
They will bolt up. the ports arnt any bigger. The valve spring is "slightly" larger.
Yes they make headers for the 3.4l, however, all the accessorys, etc., that bolt on to it, and around it are different.
If you can make them work, be our guest.
Old Feb 26, 2003 | 11:13 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
3.1firebird got the 3.4 headers to work. had to, make that had his grandfather, take a toch to them & bend them to clear firewall & fit. still need y-pipe made.
Old Feb 27, 2003 | 12:18 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
You don't have to replace the heads to bolt up the 3.4 headers.. the 3.4 headers will bolt to the 2.8 heads just fine.. the reason they're called 3.4 headers is they're designed to clear the engine components on the 3.4 camaros, *not* our stuff. I don't know exactly what's in the way, but suffice to say it's easier to bend the headers than move the stuff they interfere with. After such action, a custom Y-pipe will definitely be needed, also.
Old Feb 27, 2003 | 06:31 AM
Car: 85 firebird
Engine: 2.8 HIPO
thanks for the replies guys i'm gonna look into the headers when i save some more $$$
thanks again peter
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
