Car Door Question????
Old Mar 14, 2003 | 12:42 AM
Ant's Avatar
Ant
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
I recked my camaro mainly my driver side door and I was going to go to the junkyard to replace it but I don't want to mess up my power windows or my alarm what do u guys suggest???
Old Mar 14, 2003 | 07:07 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
This should be in the paint and body section. However, why cant you find a new door that has the holes for power windows and locks, and just move your hardwear over?
Old Mar 15, 2003 | 11:52 PM
KED85's Avatar
Yeah, IF CAN BE DONE.
Strip guts from one, insert into other, done.
Don't forget door lock cylinders!
Old Mar 17, 2003 | 07:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, all doors 82-82 had the same mounting holes; but not exactly the same internal hardware. If you find a door with the same internal hardware, you can probably just plug the junkyard door's motor in, without swapping anything out. Keep in mind you'll have to realign the windows; that's a tedious (pain in the butt) job!
Old Mar 17, 2003 | 08:31 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
hmm so how hard would it be to go from manuel to auto windows and what not?
i already have the lock on keyless with the alarm....but i dont like leaning to roll down that passenger side window, maybe if i just swapped that side so i dont have to reach... , ya it would take awhile to to but it would be so worth it
Old Mar 17, 2003 | 10:14 PM
KED85's Avatar
Common sense says...
Remove the hardware for power windows from one to insert into the other.
hard part.....
Wiring.
But that is simple, IF YA SCORE THE OTHER CAR WIRING HARNESS FOR THE POWER WINDOW ASSEMBLY.
I plan on doing this to my 1974 Corvette.
I have the power window system and the wiring harness.
Remove the regulators & swap in the power regulators.
Wire up.
Done.
MAKE SURE ya also grab the fuses for the power windows. They tend to be circuit breaker fuses.
Atleast they are for my 1967 Camaro. Not sure on the 74 Corvette nor am I sure on the 3rd gen F bodies.
For that ya need the schematic to be sure what ya doing.
PS I agree it's a long reach for windows.
YET, they never fail (the manual motors!)
Old Mar 20, 2003 | 11:11 PM
icebird_1981's Avatar
open the door cut the wires, take off the door, put on the new door on(make sure it has power window on it) connect the wires put some tape around it.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
BrianI
Aug 9, 2015 11:52 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
