sum 850011 HEI Coil HELP!!
Old Mar 30, 2003 | 09:51 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
ok there instructions suXorzs!
1. remove screws holding original coil cover.
ok i got that much
2. disconnect wire leads. use small probe if necessary to extract snap leads.
umm i didnt see any!!
3. remove and discard old coil, ruber gasket, spring/carbon coil to rotr coil.
thats nice and all but how?
4. replace coil with Summit replacement.
i ask again how where?
5. secure ground lead to coil magnet
6. snap leads securely into cap as shown be sure all is tite and bladed r snapped
i didnt see anyplace to snap leads!
7. reinstall
yeah andbody have some better instructions and pics, cuz there pic sucks!!
Old Mar 31, 2003 | 07:08 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Sounds like you got an "IN CAP" Coil. Ours are remote mounted. That's why the steps seem Greek
Old Mar 31, 2003 | 02:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep. Good thing you bought from Summit, you can return it no problem. Buy the direct plug in coil. Or buy a canister style coil (like the Blaster II), and search this board for my instructions on how to wire it into the dual connector GM system.
Old Mar 31, 2003 | 06:36 PM
Engine: 3.1
ok then i new something was wrong when nothing made since i was just gettin some more info on the problem!
Old Apr 2, 2003 | 10:40 AM
KED85's Avatar
Simple solution.
Attached Thumbnails sum 850011 HEI Coil HELP!!-coil-20up-20-26
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
