View Poll Results: What is the potential of the 2.8 V6?
A ton!
25.00%
there's some good parts out there
25.00%
meah...
25.00%
get an 8 dangnabit
25.00%
Voters: 4. You may not vote on this poll
What PSI should I set my fuel pressure in my stock 2.8 V6?
Old Apr 2, 2003 | 08:21 AM
RiceKilla#1's Avatar
I have a fuel pressure regulator for my stock 2.8, now what would be a good PSI for getting the most performance out of the engine?
Old Apr 2, 2003 | 02:39 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I would say set it about 43-45 psi running.
Old Apr 2, 2003 | 04:40 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
You set it to where it runs best. But you should not set it too high or you'll be replacing your fuel pump. But, in all honesty, simply increasing fuel pressure doesn't mean an increase in performance. You might feel a little increased throttle response at part throttle, but that doesn't mean it's performing better overall.
The best way to utilize an AFPR is in conjunction with an eprom. I do believe in higher fuel pressure, but if the engine is bone stock, you'll most likely be decreasing performance due to running too rich. GM (by design) tends to make these cars run richer than normal due to warranty concerns.
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
killer777
Aug 8, 2015 02:47 PM
