2.8 block w/ 3.4 heads??
Old Apr 8, 2003 | 11:07 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i was wondering if 3.4 heads and intake will bolt on to a 2.8 block and if so, what modifications ( if any) do i need to do for it to work. i can get a pair of good heads for cheap.
Old Apr 9, 2003 | 12:28 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
3.4 RWD iron heads will bolt right up. They are basically same heads as the 2.8 and 3.1 except a little more meat in the castings and 1.72" intake/1.42"ex. valves (2.8/3.1 have 1.6"in/1.3"ex)
Any aluminum heads will NOT work.
Old Apr 9, 2003 | 03:14 PM
pontiacguy1's Avatar
Hey Agood2.8, are you sure that the things will work just bolting them on? I have heard that valve angles are splayed more and that along with the larger valves will not clear the bore on a 2.8 or 3.1 liter engine. Just askin'.
Old Apr 9, 2003 | 03:55 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
if I recall, the 2.8 is the stock block, the 3.1 is a 2.8 stroked, and the 3.4 is a 3.1 bored. As far as I know, the stroke on the 3.1 and 3.4 is the same, so it wouldn't be a problem. I don't know however if the pistons have the cut-outs for the valves though. If I remember right from when I replaced my head gaskets, the piston tops are flat in my 2.8, but I don't know about the other engines. This might be the difference.
Old Apr 9, 2003 | 04:47 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
if you're running a stock cam, everything should clear. turn the motor over by hand before hitting the starter though, always a good idea after changing internals. i disassembeled a 2.8 to use the block for my new 3.1 and it had dish pistons in it...now domes with a high lift cam and i believe the larger valves listed above and have no clearance issues.
Old Apr 10, 2003 | 09:57 AM
KED85's Avatar
Invest $6.95 in the GM Performance Parts book available at ANY GM DEALER.
Check out the 60* V-6 section to see every answer for all your questions.
Specs and pictures of aluminum & iron head the only RWD available head.
The $6.95 book & the drive are worth it!
PS ya can buy a used running complete 3.4 mill from a 1993 to 1995 4th Gen F body for as low as $210 & as high as $900.
I pay the high end prices.
IF ya buy the wrecking yards used 3.4 engine, they will toss in the heads for free!
Old Apr 14, 2003 | 05:30 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
The 3.4 has a larger bore. Thats why you can't use a 2.8/3.1 L block, walls are to thin.
I think the valves would be ok but gasket surface ring would need some looking at.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
