Fuel Injection
Old Apr 14, 2003 | 07:56 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Fuel Injection
The fuel injection system on the 2.8L is non-sequential, correct? Is there a way to convert it to sequential?
Old Apr 14, 2003 | 08:35 PM
funstick's Avatar
as far a s i know theres no real advantage to seqential.and your ecm is batch fire.
Old Apr 14, 2003 | 08:50 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
They basically are sequential- firing order on a 60*V6 is 1-2-3-4-5-6
Right bank 1-3-5 Front to rear
Left bank: 2-4-6 Front to rear
Old Apr 14, 2003 | 10:51 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I do not believe the fuel injection is of sequential style... I think the right bank fires, then the left. That's about it. I'll have to look this one up.
Old Apr 15, 2003 | 01:29 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Batch fire, AFAIK... Also, no real advantage of batch fire vs SFI - unless you've got variable valve timing to boot.
Old Apr 15, 2003 | 12:12 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
There is an advantage to SFI, it allows for better A/F control, allowing better milage, emissions, and power. Why do you think the LS1/LT1 motors are SFI? Not because GM thought it would be fun. It also allows the computer to sense bad injectors and crap like that, that way it can narrow problems down to a single cylinder.
Granted the difference isn't worth it to us, nor will it make a difference on our cars, but that's the reasons makers choose to use it, I'm sure.
And just to make sure we know, it's batch fire. That's why you can look at the wires on the injectors and the left side all have the same patterns, and the right side all has the same patterns. Also, the wiring diagrams all show the the injectors for the two sides are wired in parallel.
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
86Base
Aug 13, 2015 05:06 PM
