TV detent cable swap
Old Apr 21, 2003 | 07:21 PM
dsaint1347's Avatar
I just recieved a new TV detent cable and I was wondering how hard is it to swap and to expect. The reason I am changing the cable is because the metal tang that adjusts the detent cable is frozen stuck.
Old Apr 21, 2003 | 07:58 PM
Xceleratemaro's Avatar
ez to put on the transmission on 10mm bolt and pull out and unhook..(youall see) and rehook.. the hard part come when you need to hook it up to the motor...i could not get my old one out so i just rehooked the old one to new trans..
Old Apr 21, 2003 | 09:09 PM
dsaint1347's Avatar
I figured that would be the hard part. I tried using pliers to squeeze that plastic part but to no avail.
Old Apr 21, 2003 | 09:32 PM
Soft Taco's Avatar
its not hard, but its a pain in the butt.
I hate dropping the tranny pan, its times-taking, but its not hard at all.
Old Apr 22, 2003 | 12:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
From what I remember (although it's been a few years), you don't need to drop the trans pan. Remember to clean all the dirt/grime away from the grommet where the TV cable enters the trans case BEFORE you undo the 10mm bolt at the trans. You don't want crap falling into the pan!
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
