MAF location...
Old May 1, 2003 | 07:00 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
MAF location...
Does it matter where in the intake stream the MAf is located? Obviously it needs to be AFTER the air filter, but does it matter how close to the TB it is?
Also, what other options do I have for PCV valve tubing that normally ties into the intake pipe right before the TB...
Currently I've adapted the intake assembly from an '87 Regal Grand National, and it works fine, but the filter is a little cramped down in the corner with the MAF sensor having that bend in it... I just want to clean it up a bit...
Thanks for your thoughts...
Old May 1, 2003 | 07:11 PM
Xceleratemaro's Avatar
yea i think is maters to an extent..not sure the didstance that you can have between the tb and maf!?
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
