TPS adjustment
Old May 2, 2003 | 05:08 PM
David Blalock's Avatar
TPS adjustment
Read a little article about 5.0s in Car Craft and they reccomend checking the TPS voltage so I did a search, couldn't find anything after wading through for a half hour so forgive me if it's been asked. First of all, can you adjust it, second how do you, and third what did you see in gains power wise (doubt it) or just throttle response or gas milage.
Thanks,
David
Old May 2, 2003 | 05:47 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Your idle will be higher no doubt, other than that im not sure.
Old May 2, 2003 | 05:49 PM
SLP_GTA's Avatar
search
TPS enhancer
this will answer all of your questions
Old May 2, 2003 | 07:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The tps enhancer is worthless; does nothing except waste your $$.
Adjusting your TPS for the proper voltage is not a mod. Voltage should be within spec or your engine runs poorly, that's all.
You missed the Tech Central area, off of thirdgen.org's main page... the link is here: https://www.thirdgen.org/newdesign/tech/tpimod2.shtml Our v6's use a slightly different voltage spec, 0.55 volts +/- 0.05 at idle.
So power, throttle response, and gas mileage can be improved just because your computer will "really" know where the throttle is. It's not really a mod, just one of those things that people forget to do (like checking the TV cable adjustment for an automatic transmission).
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
FormulaEngland
Sep 30, 2015 01:50 PM
