Backfire...
Old May 4, 2003 | 11:40 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Backfire...
Dunno if backfire is the right word... I've got a very odd 'pop' from the #6 cylinder. It's not constant. It'll be reving, or idling, and then it'll just go 'POP' and continue idling normal. 30 seconds or so later... one more pop. Always just one pop. Any ideas?
New cap/rotor, just rebuilt the distributor.
A little background - I rebuilt the distributor, as I'm chasing a power loss problem. Driving along, and the car like.. misses. It's not a constant thing, just a quick stumble, but bad enough that the car jerks.
Any ideas?
Old May 4, 2003 | 01:55 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
you rebuilt your distributor... did you set the timing properly? Also check on that ignition module underneath the cap. Get some good dielectric grease and lube up the underside of that module and put it back in. They need a regular greasing every 6 months or so. Hope that helps you out.
Old May 4, 2003 | 02:45 PM
Doward's Avatar
Yes... re set the timing without the est connector connected, and had to wait till yesterday to get teh dialectric grease for the ICM. Any ideas?
Old May 4, 2003 | 03:47 PM
funstick's Avatar
did you do the timing chian cam and stuff ?? if so it possiable you over lashed the valves.
Old May 4, 2003 | 04:32 PM
Doward's Avatar
Haven't done the cam yet, so no valve work to speak of
Old May 4, 2003 | 07:25 PM
funstick's Avatar
if you did the timing chain id highly sugest checking the timing. its also possiable you put the distributor 180 out.
Old May 4, 2003 | 07:33 PM
Doward's Avatar
Not sure how I'd have the distributor 180º out... I mean, the relationship of cap/rotor/wires only go on one way. If I had teh shaft itself twisted 180º, the car would run indifferently, wouldn't it? The shaft is symetrical - one side is teh same as the other. As long as that rotor spins the right direction, and is pointed to #1 on the cap @ #1 cyl tdc, then all is good
Jimmy D
Jan 5, 2009 06:06 PM
Twilightoptics
Aug 7, 2003 10:59 AM
bigals87z28
Mar 15, 2003 05:28 PM
