Electrical Gremlins
Old May 10, 2003 | 12:36 AM
AA88Fbird's Avatar
Electrical Gremlins
The demons have struck the 88Fbird V6. Heres a list of what does not work (in order of significance to my 16yo son):
1. Radio/Clock
2. Door locks
3. Dome light
4. Turn Signals
These items just quit working all at once.
Any suggestions on potential cause(s)?????
Old May 10, 2003 | 12:48 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Fuse, its a 20 AMP that runs all of those. I think it says Courtesy on the panel.
Old May 10, 2003 | 05:44 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Radio/clock, dome, and door locks are on the accessory fuse...
Turn.. uhh.. I could swear those are on a different fuse.. but then again, they do only operate when the car is "on"... Your son probably managed to short/overdraw the cigarette lighter and take the fuse out. 20 amp, labelled ACC
Old May 10, 2003 | 10:16 PM
AA88Fbird's Avatar
OK. The accessory fuse fixed everything but the turnsignals.
Where are the "flasher" units physically located?
Old May 11, 2003 | 01:53 PM
AA88Fbird's Avatar
Found them, both of them.
One is mounted on a drop down board under the panel beneath the steering column. The other is "dangling" just inboard of the fuse panel. Hope this helps somebody else, too.
Old May 11, 2003 | 05:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
He doesn't keep change in the ashtray, does he? Those coins are a perfect match for shorting out the lighter socket! My blinkers were reallly slow a while ago... everyone was telling me "battery! alternator!", but they were fine. Dropping in a new blinker can fixed it... the blinkers blink at a normal speed now. Only thing I hate about the new can is that it's electronic, and not thermal... when I use the "lane change" feature of the blinker switch, I don't get an immediate blink out of the blinkers. It takes a second or so for the blinker to kick on- and by then, I've already changed lanes. I gotta dig up an original GM blinker one of these days..
Old May 12, 2003 | 03:19 PM
AA88Fbird's Avatar
Yes he does, er did. He doesn't anymore. Hope TomP is well.
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
lanceflame44
Sep 25, 2015 12:28 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
