V6 belt question
Old May 14, 2003 | 07:31 PM
Cold Dark Shado's Avatar
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
V6 belt question
I was wonderin on my 85 camaro its got a belt that runs to the AC compressor down to the power steering pump(i think thats it) then to the crankshaft.
Can i just pull that belt off(cuz i think i have a bad AC compressor) without it affecting anything??
There is a second belt that runs to the power steering pump but if i remove that other belt will it affect anything???
Old May 14, 2003 | 11:24 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
my 2.8 had 1 belt going to the ps pump pulley. Let's see a pic of the belt, right now if you remove the belt you:
a) have no a/c
and
b) have worser steering than manual steer
edit: does your ps pulley have 2 groves or 1, & is it serp or v belt.
Old May 14, 2003 | 11:30 PM
Engine: 305 carbed
Axle/Gears: unknown
Heres the only pic i have right now of it but i can get diffrent ones in the morning if needed
PIC
The PS has 2 grooves
Old May 15, 2003 | 09:37 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL! I just answered this in your "eek something's melting" post!
Originally posted by TomP
If the a/c compressor is causing a problem, you can always yank the drivebelt from it. If it's an old drivebelt (looks glazed and has cracks), you may as well just cut it with a knife and throw it away; then you don't have to take the other two belts off. And if all 3 are old, think about changing the belts soon...
I have the same setup as you do on my '86; p/s pulley with 2 grooves. I removed my a/c back in '96; only one belt remains on the p/s pump.
Old May 15, 2003 | 06:12 PM
Engine: 305 carbed
Axle/Gears: unknown
LOL yea i seen that
I think im goin to remove it cuz when i moved the car today it sounded like the compressor was whining
1992 Trans Am
May 10, 2023 07:19 PM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
