T-top seals
Old May 21, 2003 | 09:58 AM
crazyta1989's Avatar
T-top seals
Anyone know how to repair a seal that has a hole in it and leaks without having to purchase a new one it is the t-top seal on the car.
Old May 26, 2003 | 10:15 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
How big is the hole? Pieces missing, or is it a tear? My top seals are damn near perfect, BUT they leak like a sieve when I wash the car, because the glue that bonds the seals to the body has dried up...
You might be able to literally Krazy-Glue the rubber back together, and just be careful later to not bend the joint too aggressively... Also, see about the cement that is used to patch tire innertubes.
Another tip: On a sunny day, wipe the seals down with Vasoline, and let them sit in the sun. The rubber will absorb some of the petrolium, and expand a little, giving a better, longer lasting seal. This works with the decklid gasket as well. It will also keep the rubber soft and pliable longer.
Old May 27, 2003 | 12:27 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
There's a black sealant for cars that you can buy, I'm sure it's pretty common. Fill your defect with plenty of that, cover it with plastic wrap (from your kitchen) and then put the t-top back on. The sealant will dry in the proper shape.
Also BackInBlackGP has a very good point with the vasoline. Quite often the seals will dry out in the sun, and then when you get rain for the first time in a while you get major leaks. Although there might be something better than vasoline out there. Maybe something made specifically for moistening seals.
Old May 27, 2003 | 01:30 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Ditto on the Vasoline!
Old May 27, 2003 | 08:54 PM
See, Vasoline is good in the bedroom AND the garage...
Old May 27, 2003 | 09:32 PM
Vasoline in the bedroom BackInBlackGP? Come on you can find something better! (I was thinking of motor oil)
Old May 27, 2003 | 10:12 PM
Nope. My wife specifically disallows garage items in the bedroom...
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
