code 35
Old May 21, 2003 | 06:47 PM
confucius101's Avatar
code 35
ok if i read everything right i got a code 35 today.
what is this and or what does this mean in english
35. Idle speed can not be set to desired RPM
Old May 21, 2003 | 07:13 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: code 35
Haynes Manual
TPS sticking or misadjusted; poor elcetrical connection; open or short in circuit; defective IAC valve; defective ECM
chances are that you're TPS or IAC may be unconnected or even bad. I doubt you have a bad ECM.
Jeff
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
