Shift Kit
Old May 23, 2003 | 09:39 AM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
Transmission: TH-700R4
Shift Kit
hey guyz...i haven't been here in a while...quick question...i wanna put a shift kit and since its only a 6 i just want a mild one to hold the gear a little longer...this should be posted in the tranny board but you this is where i ask most questions...how is the b&m shift improver kit...i've heard both good and bad...any suggestions...also...how bout the tcc lockup switch that only lets it lock in 4th gear...i have premature locking of mine and want to stop it however need that lockup for gas mileage...any suggestions would be great...
Old May 23, 2003 | 11:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Shift Kit
Best bet is to get TransGo. Actually, it is the _only_ one to get. Do a quick search on the tranny board and you'll see why.
I put one in mine and it's grrrrrrreat. I used one of Pro-Builts custom setups.
RBob.
Old May 23, 2003 | 11:30 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
If all you want to do is hold the gear longer the all you need to do is change the governor to a lighter weight unit- Put a V8 gas governer in it and that will rasie your r's- you can get one from any tranny shop or junk yard- takes 5 mins to change. Its the round domed cover on the drivers side rear of the trans. Just pop the cover off with a big srcewdriver and pull the governer assembly out (nothing else will fall out- its pretty simple to do)
Edit: the lighter the springs and weights on the governer, the higher your shift rpm's will be.
Don't use a Vette governer unless you are running a V8- we don't put down enough power and it will hold your shifts till your rpm's go through the roof
Old May 23, 2003 | 09:15 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
what's wrong with the B&M transpack?
Old May 25, 2003 | 11:56 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
i dunno whats wrong with it, its cheap and i got one (BRAND NEW IN BOX) that im un sure about putting in.....
135,xxx miles and counting....
Old May 26, 2003 | 02:06 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The B&M Transpak is the exact same kit as the B&M Shift Improver Kit. You pay an extra $20 for a filter.
The B&M gives hard shifts but does it "the easy way", and hurts the trans. The Transgo kit gives you firm shifts and helps your trans last longer.
Old May 27, 2003 | 10:58 PM
92 Red Firebird's Avatar
Your saying that it's better to go with the Transgo Kit? What is the complete name of this kit, and where can I get more info on it?
What does installing this kit involve? Would it be best to leave it to the pros to put in?
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
