86 sport coupe console help!!!!!!!
Old Jun 8, 2003 | 01:19 PM
camaro123's Avatar
Hi, does anybody knows what is on the console up to the radio is a blank black face, my question is can I make a hole for the aftermarket gauges or is something there in the back of that plate????
Thankx
Old Jun 8, 2003 | 02:19 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Welcome to the boards. I think you should be able to put gauges in there no problem, but I'd also run a search because I know it's been done before, and you can get a few tips on it as well. good luck.
Old Jun 8, 2003 | 02:23 PM
camaro123's Avatar
gauges
Ok, thank you very much for your responce.
X
Old Jun 8, 2003 | 06:13 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Can you explain what exactly it is you're asking? And what is it you're planning to put on in the way of gauges. I have the same car as you, and I added an aftermarket tach. I attached it to the right side of the cigarette lighter/rear defroster block. It looks pretty slick.
Old Jun 8, 2003 | 06:34 PM
camaro123's Avatar
gauges
Hi, yes is on the right side next to cigarette lighter.
there is a blank face and I want to make three holes for my gauges, but I don't know if is somrthing back there.
Thank you
X
Old Jun 8, 2003 | 07:00 PM
I actually mounted my tach to the cigarette lighter part and not the face below the dash. But the best advice I can give you is to take off some of the panels, the dash, and things like that to see where there is room to mount your gauges. It's not really hard to take some of that stuff off, and at least that way you will know for sure that you're not going screw something up.
Old Jun 8, 2003 | 07:03 PM
camaro123's Avatar
gauges
Yes you are right that is what I will do.
Thank you X
Lbibb
May 5, 2016 12:00 AM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
LT1Formula
Oct 8, 2015 08:34 PM
ndndndnd
Sep 28, 2015 08:00 AM
