v6 Compression
Old Jun 11, 2003 | 02:09 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
v6 Compression
does anyone know what the compression is soposed to be on a v6?
Old Jun 11, 2003 | 02:18 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I read 160 on mine.
Honestly, it's not the number you're looking for on a compression test... You want less than 10% variance among all 6 cylinders. All mine were 160psi +/- 5psi - nicely within spec.
Unless you mean compression ratio... 8.9:1 on the 2.8 mpfi.
Old Jun 11, 2003 | 02:21 AM
Xophertony's Avatar
Axle/Gears: n/a
i knew about the variance thing, but i did not know what they should be in general, i am planning to test that 86 before i buy. new engines should have good compression
Old Jun 11, 2003 | 02:27 AM
Doward's Avatar
a new engine should have 155+
If he's installed a longer duration cam, tho, well... the dynamic pressure at such low rpms will bleed off pressure quickly! There should be less than 1% variation, tho, with a brand new engine.
Besides, just look at the engine. If it's all gunked up, you know it's not new, right?
Old Jun 11, 2003 | 02:30 AM
Xophertony's Avatar
Axle/Gears: n/a
my stepdad (evil person) used to be a used car wholesaler.he used to pressure wash engines and spray them with laquer to make them look new. i have heard lots of tricks
Old Jun 11, 2003 | 02:40 AM
Doward's Avatar
Like you said earlier... what goes around, comes around...
Old Jun 11, 2003 | 02:43 AM
Xophertony's Avatar
Axle/Gears: n/a
boy does it, he is now in jail for mail and insurence fraude. belongs there too. hope i never see that pathetic waste of life again
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
