bird parts into a camaro
Old Jun 13, 2003 | 09:38 AM
aaroedg's Avatar
hey guys, i need a couple parts, i have a camaro, all the junkyard has is like 4 firebirds. i was wondering if the front seats would bolt into my camaro, and also the hydraulics (the ones that hold up the hood and hatch) thanks
Old Jun 13, 2003 | 09:40 AM
Redbird87's Avatar
Engine: 355
firebird to camaro
Yes
Old Jun 13, 2003 | 10:20 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Look in other GM cars for seats, too. Chances are good that your seat rails (between seat cushion and floor) will bolt to other seats. For instance, my car had seats that I could never find in junkyards. (Found out later that they are trans am seats!) One day while hunting for seats, I saw a Pontiac 6000 4-door wagon. My buddy had a Pontiac 6000; lots of fun times in that beater, so I walked over to take a look- and saw my seats in it!! It was a "Pontiac 6000 S/E", and my seats were in there, in perfect condition. (Two-tone, separate adjustable headrest) Got 'em for $10/each, unbolted the seat rails (very tall!) from the seats, swapped my car's rails onto those seats, and they bolted right in.
Even further- it was a 4 door, the seats didn't tilt forward. Well, I took the sides apart, and installed my tilt-forward mechanism into the "new" seats' frame. The headrests even had holes underneath the fabric (found them with a sewing pin) for my seat belt loops!
So check out other cars, too.
Old Jun 13, 2003 | 10:24 AM
aaroedg's Avatar
holy i didnt know that i guess i will have a bigger selection then i thought lol. yea those wagons and there seats hey?! my brothers 84 tercel wagon has nice 2 tone bucket seats in it! thanks alot for the advice i will look at other gm cars for sure!
Old Jun 13, 2003 | 02:21 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
hey, is toyota gm? might want to bring your seat rails with you to compare. seems like a good plan. while your looking at all cars check out jeep charokees. kick *** seats.
Old Jun 13, 2003 | 03:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What you could do to make life much easier is this:
Remove one of your front seats, flip it over, unbolt the rails from the seat bottoms (4 very ridiculously long 10mm bolts). Lay a piece of paper or a pizza box cover over the bottom of the seat, and mark where the 4 holes are. Bang, you've got a template.
When you go to the yards, bring a socket set and that template with you. All you have to do is pull a seat, remove the rails, and lay your template over the holes; if it fits, you've got seats.
Another thing you could do is make adapters. Home Depot sells strip stock - flat pieces of steel, 1/2 inch up to 2 inches in width, in 3 foot and 6 foot lengths. You might be able to make flat adapters that change a seat's bolt pattern to fit the f-body rails.
Good luck!!
There's something with Beretta and Cavalier seats where the seat rails use some kind of "wheel" setup... they don't bolt to the floor, they ride in some kind of track. So definately use the template on the Beretta-style seats. You'll see what I mean at the junkyard.
Old Jun 16, 2003 | 01:53 AM
aaroedg's Avatar
ok i got the pass seat out and made that paper stensel thing u said (good idea) i have to wait till mon when the place is open. so tomarow ima go in there and find a couple seats, i will let u know what i get and see if i can get a hold of a digital cam.
Navy8125
Aug 22, 2015 07:13 PM
aaron7
Interior Parts Wanted
Aug 16, 2015 06:07 PM
Catcher55
Aug 15, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
