Quick question about the V6 intake plenum
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Well, I pulled mine off yesterday for a few reasons, first im gonna replace my thermostat and put a 180 degree temp one in. Second, I got a new wiring harness coming sometime this week and will make life easier if I take it off.
On to my real question now, I hear so much about polishing the TPI intake plenum and was curious if it could be done to the MPFI,
I would imagine it would basically be the same procedure (although a bit harder due to the shape of the MPFI's) basically my main concern is, will it hurt the internal workings of the car in anyway. Thanks.
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
There is not much you can reach in the plenium to help airflow. The way the runners are attached to it pemanantly makes it difficult. The biggest restriction in the MPFI system is where the upper and middle sections meet. The upper section of runners and middle runners make a very sharp aprox 135* bend. I am currently fabbing a new upper plenium that will be completely open space plenium that dumps into the middle runners- no funnel bends. It will be like the V8 superram setups. I have tried some porting on the stock upper intake/plenium so far and am not happy with the restriction areas- thus have stopped that project for now and am designing a new setup.
https://www.thirdgen.org/techbb2/sho...hreadid=185591
Getting it from a junk yard, it has the "it don't work, get your money back" gaurantee. Found it at car-parts.com.
i ground it out alot too, probably only like 2mm thick walls
i will probably have to buy a new one when i get my turbo setup on, it might not handle the boost.
Car: '87 Chev
Engine: 60*V6
Originally posted by Doward
Pics? I want to see what the stock upper looks like, ported out.
I'll probably get some pics soon as I pick up some sand paper to do the job, gonna do my rims while im at it too.
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
You could always find a machine shop that could extrude hone it... expensive, but very effective.
Car: '87 Chev
Engine: 60*V6
Pac J
May 17, 2020 10:44 AM
