Can I start the car with no transmission?
Old Jun 29, 2003 | 01:14 PM
stiers's Avatar
I have 2 possibly bad transmissions for my car, but I don't even want to deal with them until I know the engine runs...so can I just drop the tranny and try and start it or do I have to have the transmission atatched. Right now it partially atatched...I need to put on the crossmember and a transmission mount. I tried starting it the way it was and it cranked but wouldn't turn over.
Old Jun 29, 2003 | 01:34 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I would think you could drop just the transmission, you'd need the bell housing still intact so the starter can have a place to sit to start her up. But im not %100 sure.
Old Jun 29, 2003 | 02:23 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Depends. If it's an automatic, you need the tranny bolted up and in, so that the starter has a place to mount.
If a stick, all you need is the bellhousing, but I really wouldn't want to spin over the engine with nothing to hold the clutch plate centered!
Old Jun 29, 2003 | 03:15 PM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
maybe mine is just weird, but my starter bolts to my block and i ran mine with just a flexplate once. sure had some awesome throttle response
- 89 firebird 2.8 -
Old Jun 29, 2003 | 03:20 PM
Doward's Avatar
Bolts to the block? I'm pretty sure it's got 2 bolts going into the bellhousing... hey, I could be wrong
Old Jun 29, 2003 | 03:21 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
- 89 firebird 2.8 -
my starter is only bolted to the block also.
Old Jun 29, 2003 | 03:25 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
my 3.4 has starter to block. stronger that way.
Old Jun 29, 2003 | 03:56 PM
Guest
Guest
Posts: n/a
the starter bolts to the block not the trans. think about it how do that start the motor when they put the motor on a motor dyno? they don't bolt the trans on when they do that
Old Jun 29, 2003 | 06:58 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
heres another vote for block bolts
Old Jun 29, 2003 | 07:44 PM
pasky's Avatar
Maybe the autos bolt to the block? Dunno, I have a 91 manual and it goes on to the bellhousing.
Old Jun 30, 2003 | 11:19 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You sure it goes "on" the bellhousing and not "into"? It should be bolted to the block... won't hurt anything as long as there's no small animals under there near the ring gear. And definately don't let anyone go near the underside of the car when you start it up!
If the car has sat for a lonnnng time the fuel could've gone bad...
Old Jun 30, 2003 | 03:06 PM
take a closer look
i can go outside right now and look at my 91 3.1 and T5 and see that its bolted to the block
Old Jun 30, 2003 | 03:38 PM
pasky's Avatar
Not saying your wrong, but yes my does go through the bellhousing, i suppose I never bothered to look at where the bolts actually sit on, i'll take your words for it. No point in arguing with people who know a lot more about third gens than me .
Old Jun 30, 2003 | 07:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
(laughs) Just wait 'til that starter breaks; you'll never forget where it bolts to after you change it. After all these years of working on my car, it's funny how many things I can get to without having to actually "see" what I'm doing...
Old Jul 1, 2003 | 01:58 PM
stiers's Avatar
so I'm bolting up the torque converter to the flywheel, and there are a coupe different types of bolts to choose from... the Chiltons manual doesnt tell me what kind of bolt to use, but in the drawn picture, they look shorter...
is it this one?
Old Jul 1, 2003 | 02:11 PM
Engine: 4G63T
that's the one (actually three)
Old Jul 1, 2003 | 03:10 PM
Engine: 5.7 / 7.4
don't forget the thread locker
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
86Base
Aug 8, 2015 01:34 PM
Sherpajames
Aug 7, 2015 06:56 PM
