I need help gettin this thing off
Old Jul 8, 2003 | 09:32 PM
Cold Dark Shado's Avatar
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
i got the upper plenum off and i cant figure out how to get the fuel rail(i think thats what it is) off.
Im talkin about that thing right in the center of the lower plenum
Old Jul 8, 2003 | 09:45 PM
socialdeviant's Avatar
uh, 2 bolts...
wiggle side to side to get the injectors unseated.
Old Jul 8, 2003 | 09:47 PM
Engine: 305 carbed
Axle/Gears: unknown
yea, got the bolts out just the bastard is workin against me lol
Old Jul 8, 2003 | 10:04 PM
F585's Avatar
For every wire you cut on my harness I shall kill you!
Just use a screw driver and pry it from side to side.
Old Jul 9, 2003 | 12:29 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The subject of this message would make a great DVD title...
The o-rings on the end of the injectors, right before the pintle caps (which will probably break into tiny pieces) can get melted to the intake manifold; that's what's causing the fuel rail to be stubborn.
If you reinstall the same injectors, buy a new injector o-ring kit... it's made by Standard, I believe the part # is SK12, but look it up from carparts.com or something, don't trust me on it. It's been a few years! And put some engine oil on the new o rings before reinstalling the fuel rail... swipe some oil into the injector holes of the intake manifold, too. If you tear an o-ring upon reinstallation you can cause a vacuum leak (and that's why you can't re-use your old o-rings). They're a special material; buna-n I think, it's brown colored, and resists fuel.
Old Jul 9, 2003 | 12:32 AM
Engine: 305 carbed
Axle/Gears: unknown
lol yea i thought someone would bring up the thread title
I dont plan on rebuildin the motor, just tearin it down and sellin the parts. Im guttin the whole car.....
Old Jul 9, 2003 | 10:32 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh, okay, in that case, here's what I did. I stuck a big screwdriver between the lower plenum and fuel rail, and pried that fuel rail up.
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
Tonyy_z
Aug 12, 2015 07:20 AM
