Air Filter on Throttle body??? Eliminate the filter housing
Old Jul 16, 2003 | 08:41 PM
Catchen22's Avatar
Car: 91 Camaro T-Tops
Engine: 3.1L
ok.........The air filter housing on the V6 3.1L sux. I sucked water in through my air filter and into my engine. Replaced my engine and still have the same filter housing ( changed the filter of course ) I was just wondering if K&N made a special filter that will mount on my throttle body so I can raise it out of the water a little. Cause you know I want to keep my engine. So does anybody have any ideas?
Old Jul 16, 2003 | 08:49 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
one question....how/why in the world did you go through water deep enough to get it into the intake? which intake does your car have? i have a homemade cold air intake, filter is in the same spot as the stock canister. never had i problem.
Old Jul 16, 2003 | 08:51 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
What kinda water are you driving in?? Is your intake homemade or something? The stock intake is level with the headlights.....you been driving into lakes lately? The thing is, the throttle body is 3", but it's oval. If you can find a filter with a 3 1/2" or 4" inlet, it would probably work...but good luck finding one! Most are 3"...that's the universal size. Also, you can try getting a 3" inlet conical, like an Autozone cheapie import conical, and attach it to the end of that stock flex-tube coming off the throttle body. It's a tight squeeze but it slips inside. But this intake sucks, because the filter picks up hot air off the radiator, and when the fan kicks in especially, the car loses a LOT of power.
Edit: Damn, beat me to it!
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
