Fiero Heads???
Old Jul 30, 2003 | 03:38 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Fiero Heads???
Since the fiero has bigger valve covers do the heads ove bigger rockers as well??? Do the heads flow more then a 3.1 head or are they the same? And did they make 3.1 fierros i could of sworn i heard they did becasue i belive i saw one in the yeard all the ones i have herd of said 2.8 on the intake manafold but the one i saw the other day jsut said fierro on it.
Old Jul 30, 2003 | 09:54 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Fieros only had the 2.8 in the V6 version. If you saw one, it was either misbadging or a swap. The Fiero stopped production before the 3.1 was introduced.
Last Fiero made was the '88. (in the US, Canada last Fiero available was the '87, I have been told)
Introduction of the 3.1, was in '89 in the 6000 and Pontiac TGP/STE, which was also turbocharged, again in the states only.
The Fiero Rockers are still only the 1.5:1, but those valve covers are nice, aren't they?
The Fiero uses the HO head, which IIRC the '86 and up Camaro also does.
Old Jul 31, 2003 | 02:35 PM
socialdeviant's Avatar
The head swap will do not good. If you have a 87 'up camaro/firebird, then it is pointless, as you aleady have the same heads...
Old Aug 1, 2003 | 03:41 AM
F585's Avatar
The 87+ heads are different than 85-86?
Old Aug 1, 2003 | 04:51 PM
The 86-down are the small valve I beleive.
The 87-up are the big valve.
The fiero only have the HIPo big valve head.
Old Aug 7, 2003 | 08:18 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
maybe omeone's got an answer for this, but i had alwayz been wondering, why is it that the 85's came with 5 more lbs of torque than any other year 2.8L, can't be something w/ the heads, what in gods name is it with, and what changed between the years to make the difference.
Old Aug 8, 2003 | 12:52 AM
F585's Avatar
I think it is the cam that's different for the 85 model
Old Aug 8, 2003 | 09:39 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Iron head change was in 84/85. The '84 carbed 2.8 HO heads are the SAME as the MPFI heads.
Old Aug 8, 2003 | 09:48 AM
Drew's Avatar
No Fiero ever said '2.8' on the intake, they all have an application specific intake with either a Fiero decal or Fiero engraved in the plenum, it varies by year.
There isn't a single part on a 2.8 Fiero that is better than a 2.8 or 3.1 Fbody. If anything it's the other way around.
Old Aug 9, 2003 | 06:40 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Dunno Drew, the valve covers are better, still that's just for P-envy.
The internals are identiacal as far as year by year application, so......................................... not worth the effort unless you plan on just getting a set of heads to port out.
Old Aug 9, 2003 | 07:18 PM
FAST RS's Avatar
I read somewere that fieros would run mid to high 15's stock is that accurte? Several years ago i had a chance to buy one but didnt think about i i thoght it had a ugly body style. I do how ever like the later model the GT version those look sweet.
Old Aug 9, 2003 | 08:55 PM
yeah low 16-HIGH 15
Old Aug 10, 2003 | 12:13 AM
85f-bird's Avatar
Engine: 2.8L, LS1
good you mentioned the difference in body styles....while the earlier versions of the fiero, (the uglier ones) w/ 2.8L's could run those faster times , as the cars went on (and became better looking) they also gained a little pudge, so from what i've been told the later fieros can weigh in around 3k which isn't to far off from our little f-bodies, sux to ruin good things eh?
Old Aug 10, 2003 | 03:23 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I dont beleive 3k. More around 22-2500 pounds would be fair for a heavy newer V6 version AKA cooler looking fiero. As far as running quicker you do have to take in account the weight difference and the fact they have less power loss due to thier powertrain configuration, better traction due to the engine being in the back keeping the wheels planted. Still there POS cars especially if you have to touch the engine.
Had the opertunity to buy a fairly nice 87 V6 Fierro was sitting next to my firebird in the lot $600 more. I stand by my choice.
Old Aug 10, 2003 | 03:44 PM
But they are great if you can get a deal on a super charged series 2!
Old Aug 10, 2003 | 05:32 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yea those are cool. What was that movie that Charlie Sheen was in way back when? Oh Yea the Wraith. Wasent a Fierro But GM should ahve made a car like that.
Old Aug 12, 2003 | 09:32 AM
Drew's Avatar
We threw a 88 Fiero Coupe with C&C Ttops on the scale... It weighed in at 2800lbs. That's a 2.5L 4cyl with a notchback, no power options, etc... A fully loaded 86.5-88 GT with its fastback, power windows, locks, mirrors, factory sub, etc is going to tip the scales at near 3200lbs. For reference, I weighed my Iroc, Formula, Firebird, and a buddies Firebird, they all pulled around the 3500lb mark.
Fiero's hook better and the fuel injection is slightly removed from anything on a thirdgen, but unless they're modified they're fairly slow. The fast ones are the 85 SE's with the base Fiero body, the 2.8FI and a 4spd muncie transmission. The later Fiero's used a 5-spd that killed more performance.
Old Aug 12, 2003 | 04:30 PM
biff85ta's Avatar
Car: 04 Vette
They used the four speed through 86.5 and while I don`t know the quarter time I do know I smoked a 91 rs with a 305tbi on the street from a dead stop all thanks to the fact my fiero would hook like no ones buisness.
Old Aug 12, 2003 | 06:31 PM
FAST RS's Avatar
A few years bac in hotrod they had a artcle about someone who swapped a v8 northstar motor into the fiero. i think it ran like 13's
Old Aug 12, 2003 | 08:34 PM
I have seen a 427 W/Big detroit roots, could not get traction for anything, ran low 13's, but was spinning halfway down the track...
Old Aug 13, 2003 | 09:15 AM
Sparkchicken84's Avatar
so now wait if you have a non-ho 2.8 the heads would help though wouldn't they?
Old Aug 13, 2003 | 10:53 PM
try reading the thread...
it has been said that if your car is after 85? it has the fiero type head(big valve) if you are so concerned about it, look up the info at a parts store. 1.60 Ex is the big head version.
If you look up your car there, and it says that fro the exhaust valve replacement, your good.
Old Aug 14, 2003 | 06:00 AM
sorry thought I had put it was an 84.
Does anybody know if the valves can be opened any bigger then one in the fiero/ho heads?
Old Aug 15, 2003 | 12:29 AM
FAST RS's Avatar
now i really want a fiero sorry its not 3rd gen related but you gotta read this tech article and see the pictures.
http://www.v8archie.com/v8install.htm
Old Aug 15, 2003 | 09:13 AM
Drew's Avatar
V8 archie is a hack. Research it a bit, it sounds good on paper, but when you gain some first hand knowledge of the V8 archie conversion it starts to show its weaknesses.
Do you know anyone that recommends supporting a car with cement blocks rather than jackstands? V8 archie does.
Old Aug 15, 2003 | 09:52 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
All f-body 2.8 and 3.1 60*v6 version heads have 1.6"intake and 1.3" exhaust valves- ALL of them.
The 3.4 heads are the "HO Version" and has a 1.72 intake and a 1.42" exhaust valve.
Old Aug 15, 2003 | 07:46 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
not true when i pulled my 90 apart it had 1.72 valve H.O. heads
Old Aug 15, 2003 | 10:22 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Factory? Greg, are you the original owner, or could they have been swapped previously maybe?
Old Aug 16, 2003 | 02:43 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Valve swaping is big in other worlds. i hear tales of trick Buicks with a dodge intake valve and a ford exhaust valve. Long as they can cut them in, grind down the length, you can get real creative.
Matt
Old Aug 16, 2003 | 12:59 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
no, ALL fuel injected Iron Head models came with 1.72 intake and 1.42 exhaust, along with the H.O version (the last year of the carb, before they switched to FI in F-Bodies.)
I know for a fact the valves on my 89 2.8 are 1.72 and 1.42 because my heads are being ported by my freind who works at a machine shop, and he measured them before we started any work on them at all.
Two different cast iron head assemblies have been used on production v6/60 engines:
• Heads installed on standard performance V6s have 1.60-inch
diameter intake valves and 1.30-inch diameter exhaust valves.
• High output and fuel injected versions were equipped with 1.72-inch
diameter intakes and 1.42-inch diameter exhaust valves (part number
1405489)
Old Dec 11, 2003 | 06:27 PM
AusFiero's Avatar
Drop on over to www.fiero.nl for more Fiero info. We have Fieros over there running 11s with 3800SC motors. Other common swaps are 3.1, 3.4, 3.4 DOHC, Cadillac Northstar V8s, 4.9 Cadillac V8 and the ever popular Small Block Chev. All this in a package that can still out handle a lot of new cars on the road.
Old Dec 11, 2003 | 09:53 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: 9 bolt, 3.45
your scales must have been way off. 3200lbs is even over the max weight rating the car can handle. a base 4 banger should weigh around 2,600lbs, probably a little more for an 88. My 87 loaded GT weights about 2,750
the 5-spd tranny is geared better than the 85 4spd and is an all around better tranny for performance. with the 84 4-cyls 4 speed muncie was 4:10 and swapped into v6 cars can give great ecceleration but obviously top out quicker.
owner of an 85 2M4 base coupe and an 87 Fastback GT
Old Dec 11, 2003 | 09:55 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Old Dec 11, 2003 | 10:04 PM
biff85ta's Avatar
Car: 04 Vette
Dude your car is nice. It make me miss my GT but everything I have ever read on a fiero says the 4-speed is the better tranny both for durability and gearing the only advantge of the five speed is the overdrive.
Old Dec 11, 2003 | 10:14 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
well the 4 speed was available in 3 ratios, 4:10 (only 4-bangers), 3:32 and you could get 3:65 also. The 5 speed getrag is 3:61 so the higher 4 speed is barely anymore. Lot of guys use the 5 speed with SBC swaps and 3800s/c swaps
Old Dec 11, 2003 | 10:22 PM
biff85ta's Avatar
Car: 04 Vette
My understanding was the gearing of tranny on the four speed complimented the 2.8 better than the five speed but I have been wrong before.
Old Dec 11, 2003 | 10:53 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
we've got a fierro guy on here! cool. hey, do you know where i might be able to sell a 2.8 FWD block with a fresh +.030" bore? i've been wanting to sell this block, and crank, but haven't been able to find a good place to list it.
Old Dec 12, 2003 | 07:16 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I think this is one very happy V8 Archie owner. http://www.fiero.nl/forum/Forum2/HTML/025173.html
And besides, who here hasn't used cinder blocks to hold there car up at one time or another. I know I have. (I don't anymore)
Old Dec 12, 2003 | 08:46 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ive never done that.
but then again, ive known better since i was 5 or so.
anyhoo, my mom has a fiero.... we had all the stuff to do a northstar conversion, new engine cradle and all, but once i moved out of the state, noone else wanted to start the project... evertually they sold the motor and stuff..
my only complaint with the fiero right now is the shifter and clutch.... they dont feel connected that well *shrug*
not my car though........
Old Dec 12, 2003 | 09:30 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You know the problem with the cinder block thing is people do it wrong. They are designed to take loads in only 1 position, but people like using the flat sides. Which will carry loads but has no lateral support.
Set down the right way with a bord to make them flat, they have great load carrying capacity and lateral support.
I have used hunks of tree before though. Good 18-20in round pieces a foot or two thick.
Buddy just got an early model 4 cyl fiero, needs a clutch slave cylinder.
not stolen but it has no title or keys. Have no idea what to do with it. Had to peal it to tow it 5 houses down.
Old Dec 12, 2003 | 12:36 PM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
Doward here:
Fiero's are pretty cool.. I'd love to have a '87 GT, myself, as a daily commuter.
As far as weight, I was told by everyone around that i should be like 3200 lbs.
Went to a CAT certified scale (they use 'em for the big rigs) and tipped the scales at 2950 without me, and a 1/2 tank of gas in it.
Old Dec 12, 2003 | 01:05 PM
  #42
MrDude_1's Avatar
Car: 91 Camaro Vert
Originally posted by vortex
Doward here:
is that without the 1/2 tank of gas or with?
LMAO im just kidding....
Old Dec 12, 2003 | 05:48 PM
  #43
Rare87GT's Avatar
Car: 1987 Fiero GT and 1988 Fiero Formula
Engine: 3.8L Series II Supercharged
Transmission: 5 speed Getrag
Its all about what you want and how you want it. Some people diss on Fieros that's fine, its your opinion. I have enjoyed modding mine and making it the best I can. They are fun cars, but you definitely have to have a passion for it. Here are my rides.
Old Dec 12, 2003 | 10:29 PM
  #44
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
L67 :rockon:
After looking at my GP, that engine looks funny "being in backwards".
Why is the S/C pully painted?
Old Dec 13, 2003 | 08:11 AM
  #45
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally posted by Dale
L67 :rockon:
I wondered where the belt was, but now that you say that. It could slip or atleast smell bad till that paint in gone.
Old Dec 14, 2003 | 01:13 PM
  #46
txfieros's Avatar
Car: 85 Fiero SE
Watch This!
Old Dec 19, 2003 | 01:06 AM
  #47
dennis6's Avatar
Car: 1991 Camaro RS
You can list at:
http://www.fiero.nl/cgi-bin/fiero/fo...er=4&SUBMIT=Go
However I don't know if anybody is going to want it. Its a RWD Block and a Fiero uses a FWD block, even though the Fiero is RWD. Make sense?
Old Dec 19, 2003 | 01:10 AM
  #48
dennis6's Avatar
Car: 1991 Camaro RS
www.fiero.nl Forum 2 for the clutch slave info.
For the keys, get a new set of locks and ignition cylinder from the fiero store or similar.
As for the title you have to get the original owner to go to the DMV with you and get a new title printed up. Then you can get it transfered.
Old Dec 19, 2003 | 06:39 AM
  #49
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The original owner is in jail and gonna be there for a long long time. Kind of a no go on getting him to do the title. It was one of them if you want it for free, take it now or the junk yard gets it.
Old Dec 19, 2003 | 11:27 AM
  #50
Car: 91 Camaro
Originally posted by dennis6
You can list at:
no, read what i typed before; it's a FWD block. thanks for the link though, i'll give it a try. this is not a block that's been in my camaro or anything so it not a rwd block. the guy i bought it from had intended to put it in a fierro, i bought it to get the cam and stuff out of it.
