Where to get TB coolant hose?
Old Aug 12, 2003 | 07:12 AM
NHRATA01's Avatar
So I changed out all my hoses this weekend, and for the life of me, I can't find any hose that I can use for the 2 TB coolant lines. The 3/8" hose Autozone sent me was too small, 1/2" heater hose was a little too big. Tried some 15/32" fuel line hose, which was about the right size, but it can't make that sharp near 90 degree bend without kinking. I have no idea what to use now, anyone know?
Old Aug 12, 2003 | 07:44 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
they should be premolded hoses for too much $$$. You could always do the bypass for cheaper if you want.
Old Aug 12, 2003 | 07:55 AM
NHRATA01's Avatar
I may have to go with the bypass. I can't find any P/N for the pre molded hoses. I could try the dealership I suppose.
Old Aug 12, 2003 | 08:10 AM
Engine: 5.7 / 7.4
AutoZone p/ns: S-4395 & S-4339
these are the small hoses & should come up when looking up under radiator hoses.
Old Aug 12, 2003 | 09:10 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have the # to the one I used on my site.
Old Aug 12, 2003 | 09:47 AM
NHRATA01's Avatar
I'm pretty sure those 2 are the "question mark" hoses that connect to the heater core at the firewall. I had ordered all my hoses online thru Autozone, and those P/N's were on the list. The TB coolant hose they gave me was a length of "cut to fit" straight hose but its was 3/8" ID IIRC and was too small.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
